Started to locate the oil cooler doubler plate on the aft side of the left rear panel.
• Per plans, located the doubler plate by locating the matching holes in the top of the doubler plate to the corresponding holes in the oil cooler bracket on the forward side of the left rear baffle panel.
• After locating the top of the oil cooler doubler plate, use the double plate to mach drill the corresponding holes into the baffle panel, spacer and left read side baffle panel.
• Once the oil cooler doubler plate clecoed in place, marked the cut out position for the oil cooler, and then taped.
Locating the oil cooler doubler plate
Per plans, oil cool doulber plate located and clecoed, marked cut-out
