Proceeded with installing remaining doubler plates for the engine baffle side and aft panels. The doubler plates are used for reinforcing the side and aft panels where attached to the engine case via significant screws and lock washers.
For all but one of the doubler plates, they are installed on the outside of the panel, the panel dimpled for flush rivets in the engine side, because the panels fit snug against the cylinders.
