Brief Description: Engine Baffle Install - Side Baffles
• Deburred the left side rear cylinder (which is that 3 or 4?). • Cleaned and deburred the edges of the doubler plate, clecoed. • Matched drilled doubler plate and side panel. • Disassembled, cleaned and deburred. • Dimpled for flush rivet on engine side of baffle. • Riveted with AN426-3-3.5 per plans.
Left Side baffle rear cylinder, doubler plate installed
