Applied light coating of engine oil to both sides of the prop governor gasket, and installed on the mounting pad. Installed the prop governor, carefully aligning the gear shaft to the engine. Had to turn the prop governor shaft a few degrees, in seeral attempts, to easily place the prop governor against the mounting pad. Torqued the prop governor bolts per spec, used a crows foot adapter to my torque wrench.
