Brief Description: FWF Engine Control Rod End Bearings
Install the Throttle and Mixture engine control cables.
• Disassembled the hardware (nut and lock washer) on each cable in order to thread the cable through the engine control bracket. • Re-installed the nut and lock washer on the control cable. • Installed the AN315-5 locking bolt, and the rod end bearing on the end of the control cable • Position the engine control cable, in very general terms, so that the cable travel has a chance to move the fuel servo levers stop-to-stop. • Attached the rod end bearing to the fuel servo control levels using specified hardware (various washers, AN bolt, and nut.
Mixture Control Rod End Bearing
Throttle Control Rod End Bearing
Those are the Mixture and Throttle Control Cables off the side
