Ordered a 90 degree Phoenix Fitting from Aircraft Spruce which has the female coupling, and male fitting, enabling the connection of the fuel line from the pump to the fuel servo.
Installed the fuel line(s) from the FW to the pump input side, and installed rom the pump to the fuel servo via the Phoenix fitting.
Started installing DG cushion clamps to ensure no rubbing between the pump to fuel servo line and the exhaust support rod, which is in close proximity. This clamp will also provide some support to the fuel line connection to the Phoenix fitting.
Fuel Line from FW to Pump Input side, and Pump Output to Fuel Servo
