My RV-8 Build Log
Date: 4-12-2014
Number of Hours: 3.00
Brief Description: FWF Engine Control Bracket Install
Received the new Engine Control Bracket from Vans, and installed between the engine sump and Bendix RSA Fuel Servo, with required gaskets, and torqued.
Now that the bracket is installed, and it seems to be correct for my implementation, with the throttle bracket on the right side, and the mixture bracket on the left side, I can see how the engine control cables will route and attached to both the bracket, and the throttle and mixture control levers on the Bendix Fuel Servo.
Installed the fuel line from the fuel pump fitting, output side, routed to the Bendix RSA fuel servo, input side. Due to the location of the exhaust, and the length of the line, there is no way a 90 degree bend is going to happen without some sort of AN fitting to make the 90 degree turn… will be sourcing a solution since I don’t want to purchase a special line, these things are expensive.
New Engine Control Bracket Installed
Fuel Line from Pump to Servo
Well, this looks to be an Opportunity
