My RV-8 Build Log
Date:  3-30-2014
Number of Hours:  3.00
Brief Description:  FWF Engine Control Bracket, Cable FW Pass-THru
While waiting on Fuel Lube to arrive from Aircraft-Spruce, proceeded with engine control cables for mixture, throttle and prop governor.
Removed the Bendix RSA Fuel Servo from the sump, installed the Engine Control Bracket supplied with the FWF kit. There is no actual picture of this install in the plans, you are own your own to sort out how this works, which should be 'obvious'.
It is obvious this is not a workable bracket for the Bendix RSA fuel servo, as the throttle control is on the right, the mixture at the rear for this type of bracket. I have throttle on the right, mixture on the left side of the fuel servo. There is another style of bracket I found a picture of, which has to be correct for my implementation, found via Google to Vansairforce.net.
Ordered the bracket from Vans... In the meantime, drilled holes in the FW per plans for the engine control cables for the prop governor, throttle and mixture.
Engine Control Bracket Installed...
Engine Control Bracket Uninstalled
FW pass-thru for Engine Control Cables
