Installed the crank case ventilation engine breather tube. • Trimmed the rubber hose to fit the engine to breather tub. • Secured the breather tube and rubber hose via stainless clamp, same for engine. • Oriented breather tube along the FW as specified in plans, locating so that gases expelled will hit the left exhaust pipe and hopefully vaporize a bit saving the belly from a coating of oil. • Secured the breather tube to the engine mount via DG clamps, AN hardware. • Secured the breather tube to the FW via DG clamp and AN hardware.
Oriented Crancase Vent and Secured to Engine Mount
