Brief Description: FWF Manifold, Oil and Fuel Pressure Lines
• Installed the straight nipple in the engine for the manifold pressure port, installed the manifold pressure line to the nipple, not torqued. • Installed the oil pressure line to nipple which includes the restrictor fitting to the sender mount, and the sender mount. • Installed the fuel pressure line to the straight nipple on the sender mount, not yet installed on the output side of the fuel pump. • Installed the manifold pressure FW pass-thru fitting.
