Cut rubber isolators to length, Installed on the stainless exhaust support rods, these are secured using stainless screw clamps. The top end of the rod is secured to the engine sump via the bolt closest to the down rod of the engine mount.
This support method for the exhaust should minimize vibration induced bracket issues typical with supporting the exhaust by attaching to the engine mount.
Rubber Isolators for Exhaust Supports to Engine Sump
Exahust Support Rods (4) Connected by Isolators with 1/4" gap
