Brief Description: FWF Beginning.... VA1-128 Sender Mount Install
Starting the FWF, so to speak....
I'll need to source the alternator belt, and also the Fuel Line from the Bendix RSA Servo to the Fuel Divider.
I removed the battery shelf brackets, these were never rounded on the ends, and they always bothered me.... rounded the ends and reinstalled.
Located the VA-128 Sender Mount on the FW on the rivet line per the plans as shown for the O360 installation. The IO360 plans show this mount vertical with a doubler plate installed in the after side of the FW. I see no reason to do this for my implementation, I measured per plans, drilled holes for the two AN3 bolts, and installed.
I'll need to souce the alternator belt
Removed the Battery Shelf Bracket, Rounded Corners, Reinstalled
