Installed the tail wheel gear leg and wheel assembly
1. Located the tail wheel gear leg into the rear fuse, rubber mallet used to tap into place, roughly locating the matched hole for the AN4 bolt. 2. Used a screw driver shank, cross-tip, which I used the scotch brite wheel to remove some diameter, to then use to align the bolt hole in the gear leg to the hole in the weldment. 3. Inserted AN4 bolt and torqued to spec. 4. Assembled and installed the tail wheel onto to the gear leg.
