Working on the end of the canopy skirts where they wrap around the plexi bubble and meet.
The plan is to measure and cut and use a doubler plate to connect the two skirts, mark, drill and rivet using CS4-4 blind rivets, the same called for when riveting the canopy skirt to the canopy frame lower rail and ribs.
This was a bit nerve wracking until I remembered there is some fibreglass layup work to be done to finish the skirt, so any imperfections can hopefully be sorted then,
