My RV-8 Build Log
RV-8
Static Pressure Syst
5-13-2012
Locate Static Ports
Locate static ports on left and right fuse. 4" below center line rivets, and 1" forward. Used blind rivets called out in specificatino, and removed mandrel to create opening for static pressue line.
T-connector and blind reivets
blind rivet installed on right fuse
Blind Rivet looking inside left fuse.
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
