Brief Description: Fuel Tank Attach Bracket Fitting
Fitting the Fuel Tank Attach Brackets to the right and left side fuse. The brackets are naturally 90 degrees, but I need something less to get the brackets to sit flush with the fuse and tank bracket. Also, the top to bottom contact of the bracket to the fuse indicates the fuse is actually just a bit concave,
Time to remove some material from the fuse side of the brackets to get both to sit flush with the fuse, and flush with the tank brackets.
