My RV-8 Build Log
Date:  12-30-2016
Number of Hours:  5.00
Brief Description:  Aft Avionics Bulkhead Bay Stiffeners
Since the forward avionics bay stiffeners went so well. decided to add some stiffeners to the aft side of the avionics bay bulkhead. These will align with the forward side, and run from the main brace of the avionics bay to the top of the bulkhead skin where it is rivet to the top skin.
While at it, I added a mounting plate that is riveted to the two brackets that attach the GSU 25 ADAHAR to the bulkhead. I had previously done this for the GEA 24 Engine Monitor.
Located where the aft side stiffeners should be, measure and cut more aluminum angle.
ADAHAR Mount Plate rivet to Brackets
Inboard Verticle Stiffener
Inbound and Middle Verticle Stiffener
