My RV-8 Build Log
Date:  12-24-2016
Number of Hours:  3.00
Brief Description:  Van's SB 16-12-16 - Part II
After removing the control tube and forward stick, inserted the 12 AN4-11A bolts into their respective holes. Getting the washer and nut on the inboard bolts going through the pass-through where the control tube was vacated was easy to do by feel. These I could torque to ~ 65 in/lb. because there is sufficient clearance for my torque tool.
The outboard bolts required using my custom tool to get the bolt/washer combo on to the bolt, where I snug then with some good old fashion muscle memory. I performed a visual check in the thread exposure of these bolts compared to the inboard where I could use the torque tool.
A bit of Fuel Lube to hold the Washer and Nut
Inboard lower bolt/washer/nut installed
Holding the Upper Outboard Nut/Washer in place.
