Brief Description: Baggage Door Lock and Pin Assembly
Installed the baggage door lock into the bagge door, using the retainer clip and lock nut supplied by Vans. Key matches additional lock set for canopy, and ignition switch.
Installed snap bushings after reaming the inside diameter of the bushing to accept the locking pins made earler. Missing the clevis pins required to connect the pins to the locking tab, ordered from A-S.
