Brief Description: Top Skin Fitting and Final Drill Prep
Fitting the Top Skin on the fuse. Have identified 7 holes (or non-holes) on the left forward side of the top skin where it overlaps the side skin. There are pre-drilled holes in the steel weldment on the interior of the side skin and firewall intersection. Going to need a long bit to get to the pre-drilled holes from the interior of the fuse to locate properly on the side skin.
Will have to remove the rudder pedals, brake lines, etc to get inside the fuse to drill these 7 holes...
Right Side of Top Skin with Right Side Windshield weldment in place, instrument panel and baggage comp
