Corrected an issue with the righ side firewall bend angle. The plans call for an 8 degree bend n the firewall about 2/3 the way up. After trimming off the forward baggage door skin from the top skin, the firewall was not aligning properly.
Used a small board to push the firewall back to the desired 8 degress so the baggage door skin aligns as desired on both the left and right side. Basically, just man-handled the firewall a bit to get desired bend in the firewall.
Sent some pics to Vans concerning the top skin alignment with the left fuse, it's off about 1/8 inch, and it will not be so easy to tweak since the top skin is predrilled where in common with the instrument panel attach flange. I really do not think the 1/8 inch alignment is going to be an issue regarding the top cowl alignment, since the cowl has to be trimmed regardless...
left side firewall, baggage door support, and firewall
right side firewall, baggage door support, and top skin
