My RV-8 Build Log
Date: 9-12-2011
Number of Hours: 3.00
Brief Description: Throttle Quadrant Console, Fuel Valve Console
Throttle Quadrant Console, Fuel Valve Console. The throttle quadrant (not sure why it's a quad-rant, since there are only three levers), plans have changed since 2008 and 2011, I relocated the throttle quadrant bracket per 2011 plans, and used a tap to create the screw holes. First time using a tap, actually worked out very well... just took my time, did not rush, and no issues.
Drilled hole in console cover to fuel valve to pass through... Fuel valve will attached to the bracked, and the fuel valve stem will pass through this hole, enabling switching of fuel tanks (right - left - none)...
Throttle Quad Console
First time go for using a tap and die set - worked well
hole located and drilled for fuel valve
