Completed the initial cuts for the Gap Fillers and Spinner Supports. Clamped the two like pieces together in the vise and filed to remove the trace line from the template, which also ensured the two pieces were identical, which seems advantageous for getting attached to something that needs to be balanced while spinning around.
After filing, the next step is to bend the gap filler fit snugly against the aft bulkhead.
