Time to make the left wheel fairing in similar fashion to the right. Since the fairing is tilted a bit in line with the tire, I figure that marking the fairing to remove the gear leg interference by aligning with the aft fairing from the right side should give me a great start. I took me quite a bit of effort on the right fairing removing the area since there was a lot of remove and fit, then repeat. For the left aft fairing, I made a template from the right side, and used the template to trace the outlie of the cut line.
After cutting the interference area away, tested fitted and all seems to be aligning as needed.
