My RV-8 Build Log
RV-8
Fairings
7-6-2017
Wing Tip Light Lense Fitting
Continued working on the wing tip light lens, sanding and re-fitting in order to get a nice fit for the lens and the wing tip.
More Sanding Required
Sanding blocks course and fine
A better but not 100% fit
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
