Taped the skin to protect when I apply the epoxy fillet between the windscreen and the top skin. The idea is to add epoxy to smooth the transition between the windscreen and top skin, so later when fiberglass cloth is added, there is a nice smooth transition, and the cloth will not fall into the gap
I will add black tint to the epoxy mix and the glass beads, so it looks a bit better from the inside.
While trying to prime the hardener, it was a no-go. The pump will not prime. I don't think it is the pump, I think it is the can.
