My RV-8 Build Log
Date:  4-12-2018
Brief Description:  More Cowl Finishing
Performed some more smoothing work on the air inlet ramps and begin the finishing work on the top and bottom cowl (exterior) by applying a mixture of 105/205 epoxy and hardener, mixed 50:50 with acetone. Painted this on the top and bottom cowl, which I will sand, and repeat.
More Smoothing the Air Inlet Ramps
Notch on Right is for Air Seal Clearance
Finishing the Cowl
Finishing the Cowl
