My RV-8 Build Log
RV-8
Cowl
10-9-2017
Lower Cowl Air Inlet - Sanding
Sanded the filler material of epoxy and microballons of the air inlet for the filtered air box, used several grades of paper, a sanding block, and PVC pipe to get to all of the corners needed to get a nice smooth finish.
Sand the Air Inlet for the FAB
More Sanding
More and More Sanding
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
