My RV-8 Build Log
Date:  10-8-2017
Brief Description:  Lower Cowl AIr Inlet, Upper Cowl - Fill and Sand
Found and filled low spots in the lower cowl, added filler to the interior of the air inlet leading to the filtered air box for the engine. Built up the left side leading edge of the upper cowl to better match up with the lower cowl.
Filler for Air Inlet
Build Up for Left Side Top Cowl
Low Spots Filled
Low Spots Filled
