Started finish sanding the cowl to find just how much work it is going to take prepping for primer and paint. The lower cowl is smooth, I've already applied a mixture of epoxy and microballoons, so now just wet sanding to smooth the finish in preparation for primer. I'm quite sure there a lots of pin holes not visible at this point.
The FAB Ram Air intake needs some work to smooth, I had previously added some epoxy and microballoons mixture to the interior to fill some of the low spots, now sanding smooth. This will need additional work, a bit more fill and sand to get the smooth intake I am needing.
Added some more epoxy and microballoons mixture to the upper left cowl, on the leading edge where it meets the lower left cowl to bring it forward a bit so that it aligns with the lower. Sanded smooth, but will still need more finish work.
