My RV-8 Build Log
RV-8
Cowl
3-17-2016
Top to Bottom Cowl Fitting
Continued with fitting the top to the bottom cowl. For each fitting, the bottom cowl overlaps the top a bit, marked this position and continued sanding to carefully and slowly remove more material.
Getting closer, not there yet...
Left Side Trim Line
Right Side Trim Line
Left Side Trin Line
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
