Brief Description: Riveting Camloc Tabs to firewall Flange - II
Completed riveting the Camloc tabs to the firewall flange. Just to keep things a bit simple, I riveted the longer rivets first (where tabs overlapped), then rivet the remaining holes. If remember correctly, the longer rivet was AN426-4-5, and the short AN426-4-4.5.
In the lower left tabs of the bottom cowl, has to drill for the fuel drain that comes from the mechanical fuel pump.
