Match drilled the Camloc tabs, and then numbered each tab so I can put them back on without too much fuss. Deburred and countersunk the matched drill holes. The tabs overlap at the ends, so only the inside gets countersunk of the overlap portion of the tab.
Re-attached the Camloc tabs to the firewall; Clecoed every other rivet hole. I had to bend the two tabs and the left and right lower corners to fit into place. I am not sure I can use this location for a Camloc fastener, but in any case, there will be two tabs on both the left and right lower cowl, I don’t think cowl will be in any danger here... After rounding the top and making it all the way to the left side split line, attached the left and right side tabs which are below the split lines, maintaining similar spacing which left one of the tabs really near the lower corner. It remains to be seen just how difficult it will be to use Camloc at this location. Worst case, I will not use the corner tabs for Camloc.
