Installed the rear seat harnesses into the fuse. First installed the shoulder harnesses to the tabs in the fuse, relatively easy except there is not much clearance to the castle nut on the top of the attach tab.
Installed the steel tabs to the right and left fuse for the waist belts. There are two tabs per side and the idea is the harness hardware goes between these tabs. The Hooker harnesses have a soft aluminum fitting for the AN4 bolt which without modification will not fit between the steel tabs. For now, I installed the harness hardware on the outboard side of the tabs with a washer between the tabs. I don’t really like this arrangement and am contacting Hooker Harness for advice.
