Installed the Flaps. First, installed the right-side connecting rod to the flap rod end bearing, and pushed the rod though the fuse to the rod end bearing on the flap actuator bar. Carefully raised the flap and adjusted the connecting rod at the top until the flap was flush with the flap fairing. Repeated on the left side.
