My RV-8 Build Log
RV-8
Flight Control
8-20-2015
A/P Pitch Control Wiring
Make wiring harness for Pitch Servo. The servo is one end of the CAN buss, as well as having up/down control inputs for the elevator trim motor, inputs are located on the forward control stick.
Wiring Harness
Pitch Servo
Pitch Servo
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
