Brief Description: Flap Position System Control Box Install
Installed the FPS Controller under the left console.
• Created a template for the two holes in the Controller built-in bracket. • Used the template to locate and drill holes in the left console. • Enlarged the two holes for flush screws. • Dimpled the two holes for the flush screws. These will later be covered by a console pad from a 3rd party TBD ! • Mounted the FPS Controller using flush screws, washers and AN365-1032 nuts.
