My RV-8 Build Log
Date:  9-26-2015
Number of Hours:  4.00
Brief Description:  Forward Control Stick Mods
Cut off ~ 2 inches from the forward control stick in two passes. The first cut cleared the bottom of the instrument panel, but insufficient room for fingers.
Each wire is labeled within the stick and also where they exit the stick. (8) wires total.
Now the forward stick clears the bottom of the instrument panel and there's sufficient room for fingers.
Remove ~ 2
Remove ~ 2", located, drilled and tapped new rentention hole
Installed in fuse
Installed in fuse
Wire # and Purpose.
Wire # and Purpose.
