My RV-8 Build Log
RV-8
Replace Main Tires
While prepping the place for first taxi, checking the tires and found they are not suited for taxi, much less flight. These are 8+ years old, tread depth is fine, just dry rotted / split. Order some new Condor tires and tubes from Aircraft Spruce.
8 year old tires ...
... are not going to cut it
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
