My RV-8 Build Log
Date:  5-12-2019
Brief Description:  Left Wing Tip Lighting
Cleaned and Alodine the left and right landing / recognition light cover plate and mounting bracket. Installed the left-wing tip cover plate, and in stalled the SunRay Plus landing / recognition light using the Aeroleds supplied hex head screw and lock washer. Adjusted the angle of the light so it should be aligned parallel to the center line of the aircraft.
Re-tested the navigation / strobe and landing / recognition lights before installing the wing tip on the left wing.
Ready to perform the same installation for the right wing tip, but, waiting on the return of the 2nd Aeroleds SunRay Plus light from the RMA, where the recognition light function works, but the landing light does not work.
Left Wing Tip Interior View
Left Wing TipNav/Strobe & Landing/Recognition Lights
Left Wing Tip Nav/Strobe & Landing/Recognition Lights
