Brief Description: Rudder and Rudder Light Re-Installation
Re-installed the Rudder with all new HW, I hope it is the last re-installation before flight. Re-installed the rudder light and reconnected the Molex plug to the plug wire. I changed the routing of the wire for the rudder light. The previous VS had a 1/2" hole in the VS fir the wire and moles plug to pass. For this VS, I passed the wire over the HS rear spar, and routed between the VS/HS fairing attaching to the VS rear spar via a cushion clamp to hold in place as the Rudder moves.
