Brief Description: Rudder Installation and Fairing Check
Installed the rudder to the VS, which surprisingly required only a small adjustment to the center rod end bearing to run it in 1 full turn. The rudder clearance with the top of the VS was perfect, no issues. Installed the existing VS to HS fairing to see how it fits since both the VS and HS are new. Some adjustment is required, it is a bit tall around the fuse and no longer sits flush against the fuse.
