Brief Description: New New HS Build Rear Spar Install
Proceeded with cutting the elevator horn relief notch from the lower flange of the HS rear spar. Installed the center elevator hinge bracket with AN3 bolts (new hardware) to the HS and torqued to 25-30-inch pounds. Installed the rear spar on the HS, clecoed and riveted.
