My RV-8 Build Log
RV-8
New New HS Build Riveting Skins
Began to rivet the HS skin to the nose rib, used wood blocks to support the rib, and clecoed the skin to the work table to keep everything from moving.
Riveting skin to a rib
Supporting the rib for riveting
Nothing moving here
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
