My RV-8 Build Log
RV-8
New New HS Build Assembly
Assembled the right side of the HS, proceeded to match drill the skins to the ribs and rear spar.
HS Clecoed for match drill
Match drill skins to ribs
Match drill skins to rib and spar
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
