My RV-8 Build Log
RV-8
New New HS Build Fwd Spar
Proceeded with bending the forward HS spar at the bend line to match the reinforcement angle at 6 degrees, then begin initial assembly.
Bending the forward HS spar
Match to reinforcement angle
Starting to assemble
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
