My RV-8 Build Log
RV-8
New New HS Fwd Spar Angles
Worked on the forward HS spar reinforcement angles, marking and trimming the ends for the correct taper, filing smooth, and setting the 6 degree angle.
FOrward HS Spar Reimforcement Angles
Trimming excess
Creating the 6 degree angle
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
