My RV-8 Build Log
RV-8
New HS Build Forward Spar Riveting
Riveting the forward HS spar with the reinforcement angles and doubler plate.
Riveting the Forward HS Spar
Riventing the Forward HS Spar
Riveting the Firward HS Spar
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
