My RV-8 Build Log
RV-8
New HS Build Aft Spar EL Relief Notches
Made the cuts in the rear HS lower spar flange for the elevator horn clearance. Drilled holes in the corners, then cut the excess with a Dremel cutoff wheel, then smoothed with a file.
Holing the relief notches for the EL horns
Basic cuts needing filing
Smoothed via file
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
