My RV-8 Build Log
RV-8
New HS Build Prime
Sanded all parts with scotch brite pad, cleaned and primed. Marked and removed the relief notch for the elevator horn for the lower aft HS spar flange.
HS parts primed
HS Parts Primed
Releif notch for EL Horn Clearance
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
